I have a 2012 yardsport 700xlt that started with a high idle, I changed out the throttle body but it was still too high. I then messed with the throttle cable positioning and now it will run for about 30 sec. and then as soon as I touch the gas it sputters and dies like its getting too much gas. I've changed out the filters and checked the pump. It could be something completely else but a mechanic told me to reset the engine management system but all I know to do is take the battery cables off and touch the 2 ends together.
I believe my 2015 HiSun you hold the gas pedal to floor and let it hit the rev limiter for 3 seconds and shut the key off.  Im sure someone else will chime in and let us know if I am incorrect. Hope I was some help.
Register a new account
Sign in
    • By Troy C
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By LeMay624
      Hey guys! Was wondering if anybody has had any experience in shutting up a Kioti K9 or Kioti Mechron.  I daily drive a K9 in an underground mine and between the engine noise and belt whine I can’t hear myself think while driving this thing! 2-5 hours a day. It’s a 2021 model with 180 hours on it. Belt and clutches are clean, machine is maintained to factory recommended schedule and then some. Has been like this since new. Before I start boxing in the engine with plywood and stuffing insulation under the seat I thought I would reach out and see if anybody has run into this before!
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • Get More For Your Device
    • By Brett
