I've done this before. What I've always done is use the part number, and do a search on Google or whatever search engine you prefer. Then you can find out if anyone else manufactures the item in question. You could also do a search using the term "voltage regulator 2019 Brenneke T-boss 410". That's all I can suggest.
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By shawn b
    • By TPlummer
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
