Land Pride Trekker, looking for a factory fit roof
Al Ward
Hello
I have a 2007 land pride Trekker, just like the green one in the picture. I'm looking for a "factory fit" roof like the red one. Does anybody out there know who made the original roofs for this unit, or if there is a similar one out there available?
The flat ones available from power sports dealers or e-bay won't fit properly, because the roll cage bars protrude higher than the sides of the cage
Any help would be appreciated
thanks
1410627596_trekkernoroof.thumb.jpg.18614c3b333b3d7809fe62c3a9fa9362.jpg144373721_Trekkerwithroof2.jpeg.f8a60f711ae1237bf94ef30372153662.jpeg
    • By Jon V
    • By diamondjfarm
      Thanks.
    • By mac66
    • By sxr951
    • Sell your car with CarBrain
    • By Stan Morton
      My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850.  If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance.  Kind Regards, ~ Stan
