Land Pride Trekker, looking for a factory fit roof
By Jacob E freeman
By Kingfish
By Clayton Walker
After searching all summer, I finally found a company that makes a cargo rack and roof rack for the UForce XL, and I wanted to share it with fellow UForce owners. I know this is my first post, but I’m just trying to save others the time I spent researching. I bought one for hunting, and it works great, so hopefully, this helps anyone looking for a similar setup.
By Jon V
