Help! I washed horse manure off of the dump bed and underneath with a garden hose because it was smoking. It was fine when I drove it back to the house.
when I tried to start it the next day. The screen was black and it wouldn’t turn over. My husband bought a new battery and checked the fuses. I’m stressed I can’t do my daily chores without,
    • By Marie
    • By rdborra
