Are you using the switched or constant plug.  If you are using the switched plug (orange/black) you will not have power unless key is in the on position.
Ovi
OviV,
Thnx for the response.
I've tried ALL Accesory plugs under the dash & Yes I understand that the key has to be On for it to work but with the key On I still can't get Power to the switches.
I contacted my local BP & there tech informed me I had to take the dash Off & dig for the Red & Blk wires.
Just Odd that there are 3 plugs under the dash & None of them have Power!  What's the Point!?
Yes. There are no fuses or relay for the Accesories so I put a fuse in & pulled another relay & put it in the accesory block. Still Nothing.
Also, on the wiring diagram it shows all of those plugs should have power.
The Only plug that has keyed power is under the bed. Which I originally thought was for backup lights like on the Polaris Rangers. NOPE! Just power when the keys on.
It's actually kind of Comical.
I am having the same problem I M an electrician of 35 years neither one of those plugs have power behind the dash the two wire ones doesn’t matter if the key is on off whatever none of the fuses are blown I tried to put other fuses in has anybody figured out what the problem is
  • 7 months later...
  On 9/25/2021 at 2:47 AM, Chaz Dean said:
What do I have to do to get Power to my Accesory light plug under the dash?
I've wired up a light bar & accesory pods & plugged into the accesory plug behind the center of the dash but No Power!!!
Help! Plz
Expand
Which light bar did you get? Would you mind posting a picture and letting me know how you like it?
  • 4 weeks later...
Hi Folks, I just bought a 2022 Tracker 800SX Crew. Love it so far. How do I access the accessory connectors behind the LCD display. Specifically, how do I pull out the display. Please offer any suggestions for anything I'm missing. I need to install a turn signal kit and eventually a winch. Thanks for any help. I've always found these boards helpful on other intersts of mine.
    • By CapnWalleye
    • By Marie
    • By A P
    • By Joseph Sills
      Has anyone modified the panel lights so they can be dimmed ? I haven't found a wiring schematic for the display .
