I used 1 gallon of the 4 STROKE tru fuel in my mule one time... (it's mucho $$$) and it had better throttle response and pep.
ethanol attracts moisture from the second any air gets to it.
Great topic, where I live in northern Michigan we have REC 90 fuel available and it's a game changer for small engines. Being able to run non ethanol fuel is like the good old days when your small engines might sputter a little after sitting for months but they would still run.  Ethanol fuel is horrible stuff if it sits for a while.
Yes, this is a very good website. However, call before you truck over to one. Some of those listed are wholesalers. They may want you to buy a 1000 gallon minimum.  Also, they may be  out of non-ethanol waiting on a delivery.
That's all I have been using for years along with Seafoam as an additive.  I haven't had any gas engines worked on for years, this stuff is more expensive but weel worth the money.
    • By bms stallion owner
