what can I do to improve my ride quality ? are there any other coil options with a lighter rate ? can moving the shock mounting points with the stock shocks increase travel ? what can I do with the stock shocks, I have a 1 year old, am building a race car so spending money on new shocks wont happen for a bit since the money could be better spent on the race car or other stuff now
If you want a softer ride and spend zero money, just back spring tension on the existing shocks. This is not easy to do without a couple of spring tesion tools to colopse the spring a little but easier than moving the mounts. My T2's ride is/was great. You are the first who was unhappy with the ride. Everyone else who has been changing/working on the shocks are over the edge type, including myself.
What kind of race car? I have a INEX Legends, sold my SpecRacer Ford last year.
rocmoc n AZ/Mexico
I agree with rocmoc. To change suspension to make it really right, thus blast through the rough stuff without losing control or getting kicked all over, gets real involving with changing shock mounts, lowering the rear dif and dialing in along with $1000+ worth of shocks and springs. Just wait until that approach is all worked out and then copy someone else and just get it right the first time. Each of us has our own ideas on how to approach changing the suspension but I strongly sujest you follow flatbeds lead on this. I'm following him pretty close myself even though I have to try my own ideas somewhat. Flatbed generally, let me change that, pretty much always, scratch that too, is always far more correct. Flatbed has a long background in suspension from a professional suspension guy along with being a very suscessful offroad racer himself. You also might want to lower tire pressure. I have tried with stock tires 8#, 10#, 12# and now run 14#. I could knock the tire loose with 8#. 10# ran ok but I didn't hit anything major like say hitting a curb straight on at speed. 12# seemed to be the good spot so I added a little extra and run 14#.
Don't forget inner tubes. With inner tubes you can drop the tire pressure lower with more security but if you go down to 8#, bang it back up to 16# for normal use to save your tire walls.
Cheers Mike.
the ride is ok, but I hang with a rough group of guys, they have race rhinos, a class 5 open car and a 10 car. I want to be able to fly thru the woops.
As for the race car its a 69 nova that I will run in Psca limited street
    • By Grant
    • By SSgt1994
      Myron
    • By ned
      I have a Kubota RTV -X900 that I recently got from someone that is in good condition.  I'm trying to determine what year it is all to no avail.  I have the 16 digit product identification number and have gone on line to multiple sites with no luck.  The number is A5KB2FDBCFG024444 .  I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit.  Thanks in advance.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
