Coleman/Hisun 550
By Dennis
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Will Sutton
I've got a 2023 UT400 (bought from tractor supply) and I've been beating my head against a wall with it.
It will start and idle perfectly. The second I touch the throttle it sputters and dies.
I've checked that the fuel pump is working (it is).
I've replaced the injector, throttle position sensor, O2 sensor, and intake air sensor. All with no change.
I've just taken a look a the schematic, and there is a crank position sensor as well.
Could this be the source of my troubles? If so, where is this thing located? I can't seem to find it on any drawings from the parts suppliers.
By John M in Louisiana
Quick question about replacing the plug. One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs. 15amp 125v? Is it more complicated than that? I do plan to buy a plug that's water tight.
Thanks in advance!
By A P
