New guy from AZ
Thanks for letting me join in!
Looking at the Tracker 800DSX LE for my "runabout" rig and something to take the grandkids out into the desert dust and brush.
Kontra06 (Mark Porter)
    • By Paul in Wisconsin
    • By Gary Odom
    • By Karlibob
    • By Paul L
    • By Steve Waldner
