2011 EFI shuts off after running for a few mins then hard to start
So i have a 2011 EFI 700. the SxS will crank right up everytime without any issues. If i let it run or ride it for about 10 mins it will shut off and then it may turn on if i am lucky but most time i have to let it sit for like 3 hours and then it will run again. i have done the following
-New fuel filter
-New injector
-New spark plug
-New coil pack and plug wire
-New air filter
Also could i get a grizzly 660 engine and put in it or would it not work.
    • By bms stallion owner
    • By Bryan g
    • By Dennis
    • By downseast
      Hi everyone
      When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
      I haven’t changed the Lambda
      sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
      I believe the T Boss was worked on by the previous owner
