  • 2 months later...
On 9/27/2021 at 7:50 PM, Jacob E freeman said:
I’m having the same issue with a 2017 550.  It’s in the shop now awaiting a new head gasket (that’s somewhere in neverland) according to shipping info.  Also a new water pump is to be installed.  Mechanics have repeatedly bled the system but after a few hours it overheats.   It has something to do with blow back.  Once it begins to overheat, the radiator and overfill jug is filled to the brim.   One mechanic opened the radiator cap and was drenched in the pressurized fluid!   The saga will continue if I ever see the head gasket.
  • 8 months later...
  • 11 months later...
I have a 2018 750 eps that overheats just like the guys in previous post..I was wondering what they did to fix it...I took to shop that I bought it from five or six times and they said it's fixed.. It's not . Anyone have an answer for me.. Thanks...
  • 4 months later...
I had the same problem. Shaved the head, new head gasket, new water pump. Nothing worked. I ended up just buying a new drop in motor. But as I thought about it, I never checked to see if the water pump was actually turning. I am guessing that the chain that drives the oil pump and water pump spun off. If I ever find the time I am going to disassemble the old motor and find out. 2018 750 challenger crew.
What drop-in motor did you use?  Have you been happy with it?
    • By LauraLB
      Thanks for the add.  I'm looking for ideas for a hard cab enclosure. I sure don't like the soft sides and zippered window.
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
    • By Robby
    • By Gerald Mohs
      Is the cam sprocket a bolt removal or is it pressed on? Dang bolt is on tight. Impact wrench won't even move it.
