Have a 2001 Kawasaki Mule 3010 4X4. It just will not start. New battery, fuel pump, filter, replaced rusted out fuel tank,plugs and all air filters are good. It's getting spark.getting fuel to carburetor. It never ran perfect but not at all, c'mon. Any help appreciated.
  • Alex changed the title to 2001 Kawasaki Mule 3010 4X4 will not start
If it's getting fuel TO the carb... the problem is that fuel has to get through the carb....
I'm not 100% familiar with the air intake set up on this, but remove it at the carburetor and spray some Brake clean/carb clean or starting fluid directly in the carb. close the choke and try to start. if it runs then dies you probably have a carburetor in need of cleaning. You saying it never ran perfect  seems to back that up.
    • By Aaron Colona
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
