What type and brands of insulation do you use in the cabin, floor and engine compartment of your Massimo and related 4 by 4 UtVs specially Massimo Buck 400s?
what are you trying to accomplish.........?..............keeping warm in winter?.....if so, you will need a heat source.......i use a 2200 peak watt portable genny in bed of mule, hooked up to a 1500 watt space heater..............works great......no additional insulation
Well I'd also like to know what you guys in the engine compartment for sound deadening.  The 2013 cfmoto Uforce is murder on the ears.
I got some double sided foil heat shield with about 1/4 inch foam like middle off amazon. Haven't took time to install any of it yet. Have to install a snorkel for intake first. Since the intake is in the center console area.
Once snorkel is installed to allow fresh air for the intake. Then install the heat shield and block that vent in center console. That will block a lot of the heat and hopefully some of the sound.
I want the sound of the engine to be dulled in the cabin and the heat from the engine reduced in the cabin in summer.
our mule has windshield and complete cab enclosure......engine noise isn't an issue as i normally have "radio headphones" on (and engine is only single cylinder 400 cc).....as for less heat in summer, windows down and i have a 12 volt fan for air circulation.........as i mentioned before, i use portable genny and space heater for heat, plus use the fan directed toward windshield to keep "fogging" to a minimum while plowing snow..........i am not familiar with cfmoto u force, but i am sure you can "mcgyver" something..........
if you are getting that much heat from engine into passenger area, your engine may be running excessively hot.. Once I corrected my overheating problems, the passenger area is not so hot
3 hours ago, Scott Meszaros said:
mackc, do you have an enclosed cab?  is your muffler in good shape? are massimo's air cooled?.............these types of utv's are never gonna be "quiet" until the do away with gas and go electric............
cant wait to pull an electric 4 seater UTV out of the swamp because the batteries died .   ,,,,,. if its really loud, your exhaust may be cracked near the head.. common om Massimo
Mackc
Same problem with my 600 single cylinder.  Noise from engine bay. As said I have some heat shield / noise shield. Once I install it I will let you know if it makes a difference.  I'm on vacation next week and that is something I plan on doing.
I also had a 3010 Mule and sound wasn't a problem, this problem  was concerning a Massimo Buck 400.
      Anyone out there have a street legal UTV? Any idea how to get one registered for on highway use?
      Thanks in advance
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • By Gerals
    • By Jr Perez
      I need help when I put the key in and put to on position the neutral light turns on then shuts off I tried moving the shift linkage but the neutral light won't turn on it only has 651 miles cranks fine 2019 tboss 550
