I have a 2000 Chevy tracker, 4 door, 4x4, 2.0 that  I would like to change the rear differential on. I do not know the size of the factory rear end. Can anyone help with this?
thanks,
    • By Gorj
    • By Marie
    • By Grant
    • By D MAYNARD
