If you are still looking, I found this one and it works very nicely.  I think it was about $99 but with all my Christmas purchases I got it for $17.00. Not bad……. Kemimoto  on Amazon.  It’s the heavy duty 420D 2 seater.
Register a new account
Sign in
    • By rsar
    • By SouthernGypsy
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
    • By se3388
      Steve.............
    • eManualonline.com Save 30% OFF Sitewide, Use code: XMAS30
    • By mark walkom
