If you are still looking, I found this one and it works very nicely.  I think it was about $99 but with all my Christmas purchases I got it for $17.00. Not bad……. Kemimoto  on Amazon.  It’s the heavy duty 420D 2 seater.
    • By Cory J
    • By SouthernGypsy
    • By se3388
      Steve.............
    • By mark walkom
    • By Gary Gallo
