Kawasaki Mule 1000 / 2010 / 2020 / 2030 / 2500 / 2510 / 2520 /3000 / 3010 / 3020 / 500 / 520 / 550 / 600 / 610
A lot of the older mules use a float and sight glass for viewing fuel level in the tank, mine, like many others has been fogged over for several years making it hard to see the needle. I've used all sorts of cleaners in an attempt to clear it up, but none ever worked long term.
 I finally discovered this kit from ATV Works for $17.00, just the sight glass and new attachment pin (which you can not get from kawasaki)  Kawasaki want's you to order the entire float and gauge assembly for nearly $40. I ordered it last night and it hopefully should be here by the end of the week. When i get it in, i will make a video on how to install it.
    • By HighSon
    • By Karlibob
    • By Ed Michael
      Subaru SxS.mp4
