any suggestions? my 2019 mule sx fi wont idle down completely, I have to lift the box and flick the throttle lever and it comes back down.
  • Alex changed the title to 2019 Kawasaki Mule SX FI idle problem
It's still under Kawasaki's Three year warranty. let the dealer look at, no need to risk voiding your warranty by messing with it, as dealerships can be picky about that.
i always advise people, if it's under warranty, and there is an issue. let the dealer look at it. and fix it.
Same issue here.
Did you find out from the dealer what it was ?
I notice it's not the throttle cable. It's related to these to links.
If I pull either one back slightly it sorts itself out
What is that box?
The throttle cable is the one with rubber boot, is this an advance? Wondering if is a little lubricant spray might help...
I had a few of these do this and Sometimes depending on the hours the throttle plates don’t close properly due to buildup in the throttle body bore and sometimes pulling it off and clean the bores solves the issue . You would think by it not closing the idle would hang  but it doesn’t it due to the sensors giving false info to the  Ecu . There also may be an update kit to help with this I don’t remember. Like the previous reply , if it’s under warranty take it in . They can also run the vin and see if it has other needs.
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By mac66
      The good...
      -Fairly comfortable to drive.
      The not so good...
      Overall Impression...
    • By fishhouse3
      This machine is ready to go and needs nothing - just hop in and hit the trails!  I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
