2021 Tracker 800sx with 75 hours rough idle and gasoline coming out muffler
Hello All...
By Troy C
By Gerals
By Buddee
2010 Hisun 500 - Carbed'. She sat for about 3 weeks since last use. Couldn't get it started.... has spark but plug was not wet. Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working. Still nothing. Put gas in the plug hole.... started right up and idled as normal and drove perfect. Used it for the rest of the day without issue. Tried to start again next morning.... same problem. Poured gas in plug hole again.... started up and best kind again.
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
Register a new accountSign in
