Seems Kohlers have that problem more so than Briggs and stratton or Kawasaki engines
most likely the mud is the cause for the broken magnets though, it almost looks like a dirt dauber nest in there.
if you need help looking up the part # post the model and spec number of the Kohler engine.  I would advise replacing the stator as well if there any nicks or broken wires on it.
  • Thanks 1
    • By aefron88
    • By SSgt1994
      Myron
    • By Graffy
    • By Croppy38
