I own a 2020 Bennche T-Boss410 I'm having an over heating problem the temp gauge is reading that it's over heating but the radiator and lines are not anywhere hot and the fan does not work on it's own when its plugged into the connector so we wired it to a switch so it's on all the time and it still over heats. Help please?
    • By Ed Michael
      Subaru SxS.mp4
    • By Karlibob
    • By Paul L
    • By D MAYNARD
