I own a 2020 Bennche T-Boss410 I'm having an over heating problem the temp gauge is reading that it's over heating but the radiator and lines are not anywhere hot and the fan does not work on it's own when its plugged into the connector so we wired it to a switch so it's on all the time and it still over heats. Help please?
    • By Jacob E freeman
    • By Texjpr
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By shawn b
    • By MMaster
      does anyone know of a replacement temp gauge that will work on a joyner 2016 r4, my gauge has condensation in it and it quit working
