Hello I know I started this topic before but I have lost it.  So here is the story, I bought this XLT 500 earlier this year it is was and still is in rough shape the ID plate is gone, faded paint, bad window, etc...  When I got it, it ran rough and the all of a sudden  it quit running.  So I started looking into it and found no spark.  No biggie changed plug, and coil, still nothing.  So went and replaced the coil wire, still nothing.  So I have gone pretty far now.  I have replaced the stator magneto, the voltage regulator, CDI, I do have the crank shaft position sensor but have never figured out where it goes have been told around the stator but have yet to find it.  Have chased wire out and still nothing.  At the coil I have one wire giving good voltage the other one nothing, and when you crank it the voltage goes all over the place.  So besides the key I have changed every part that has to do with the starting that I can find.  So information on what I am missing or doing wrong would be great, it acts like the kill switch on the brakes is stopping it from starting, however I have bypassed that to make sure that was not the problem and still nothing.  So aside of parking this thing in the back and letting it die a slow death I am at a loss on what to do next, Help!
Ok update is that I have replaced both the CDI and the Voltage Regulator, the coil pack, the plug, I never did find the crank shaft position sensor.  I am getting power to one wire (white one) on the coil but it is low 9/10 volts not sure where it is dropping.  But still no spark and am at a loss, at this point I am ready to push it out and let the thing just go away.  Any ideas would be welcome on what I am missing.
Now that you mention the kill switch on the brakes, I remember someone posting something about a loose connection on a brake light, but don't remember which utv they were working on.  Travis also brought up the ignition switch in another thread that's up right now.
I had thought of that and bypassed it just to see it it was.  Ignition switch? it turns over but does it send a signal or something to allow the spark?
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
    • By Nikonianut
    • By D MAYNARD
