This is the most boring sub-forum I have ever been part of.  lol.  That could be because all the Kubota owners have nothing to talk about.  That is certainly what I am seeing thus far with mine (1140).  I have 16 hours (106 miles).  No issues whatsoever.
I will be doing the 50 hour maintenance this spring whether I  have hit 50 hours or not.  All fluids, all filters.  I will look up some how-to's on that.
Any gotchas that you know of?
Craig C.
On 11/5/2021 at 8:59 PM, Joe Breaux said:
If you want excitement, sell your Kubota and buy a Massimo.. ENDLESS hours of trying to diagnose and eliminate problems.. BIG FUN!
Been there.  I traded in a Coleman (Hisun) for this Kubota.  Was not a fun toy to own.
Craig C.
    • By Dennis
    • By Grant
    • By John Doe
      Hello,
    • By bms stallion owner
    • By Bryan g
