I have a 2010 ss700 4 x4 four seat side by side that will start great but after it warms up it just quits. The previous owner said that he put in a new statter, a new cdi and new carb. I took the carb off and took it to a mechanic who looked at it and he did some work on it. I picked it up and put it back on but when I started it, it did the same thing.
  • Alex changed the title to 2010 Panterra ss700 Quits after it warms up
Have you checked it for fuel delivery after it quits?
What about spark, after it shuts itself down?
You'll need to narrow it down some. Unless you're a mechanic, with proper diagnostic tools. Then these types of things are typically a simple fix, that can be a real challenge to find.
I'd start with fuel, because it's easier to verify the fuel delivery is there.
Register a new account
Sign in
      Hello All...
    • By Tarak1980
    • Get More For Your Device
      Greetings everyone! I'm a new member here and looking for aftermarket mods available for my UTV. I've got a Kioti K9 2400 cab. It's a 24hp diesel. The cab model has factory heat and A/C. It's very similar to the Kubota. Any suggestions for aftermarket parts would be appreciated.
      Cheers
