Does the charging outlet at the house have to be 20 amps ? I have a regular 15 amp outlet witch is outdoor rated and grounded (GFI) 3 prong plug. I see they call for a 20 amp extension cord no longer than 25 feet. . But these rated at 20 amp all have the "tee' plug where one prong is horizontal. Of course thay are meant for 20 amp outlets. On my 15 amp outlet, I can only use the 3 prong plug and the heaviest duty  they go up to is 15 amp rated or 14 gauge. So I have a 25 foot 15 amp rated extension cord charging my Hisun Sector e... Is that OK ? The cord doesnt feel hot or anything. Is this a fire hazard? Will it hurt the utv ?  Thanks, Bill
    • By Xov
    • By John M in Louisiana
      Quick question about replacing the plug.  One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs.  15amp 125v?  Is it more complicated than that?  I do plan to buy a plug that's water tight.
      Thanks in advance!
    • By Kingfish
    • By Jon V
      Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
