My 2019 sector 550 has developed a sort of a squeal like noise when first taking off. It’s not every time. It does have the original belt and right around 1000 miles on it. Any recommendations on a good replacement belt. Also could it be something to do with the clutch?  Thanks !
  • Alex changed the title to 2019 Hisun Sector 550 Belt Noise
Seems a bit premature for a belt, but as Travis said, it's the most likely cause, and certainly the cheapest fix. But you might also try to spin the water pump pulley, etc. while the belt is off. It should spin smooth, and easy. Any roughness you find there, could also be a bearing problem.
    • By SkyPilot56
    • By BigWave
      Bigwave
    • By GunnersTacklebox
    • By HighSon
