  • Alex changed the title to 2013 Cub Cadet Volunteer has gas on the engine oil
Most common problem is the float needle in the carburetor has failed. it's job is to meter fuel flow into the carb bowl as needed, Requiring a carb rebuild or replacement.
Do you have the model number of the engine or machine?
    • By BMurph
    • By BMurph
    • By Brett
    • By boydog40
      thanks guys
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
