Got what I hope was a good deal on a Coleman 400 aka Hisun HS400. Previous owner returned it to TSC and it wouldn’t start. I pulled the plug and it’s fouled. Cleaned it and it sputtered, but fouled again. I did test for spark after cleaning and had a nice white spark. Plug is an NGK R DR8EA. I will be getting a new plug and a fuel filter to install inline. I was going to open up the fuel tank and check for debris and drain the tank as I have no clue how old the current gas is. Currently it won’t start so just trying to get it going so I can trouble shoot the rest.
My plan.
Pull airbox and check for obstructions and clogged filters, replace.
Crank and check plug.
Disconnect 02 sensor and see if it starts
Check timing chain tension
Any other things I should look at. The plugs seem to have some oil, but that could be carbon?
Sent from my iPhone using Tapatalk
  • Alex changed the title to Coleman 400 aka Hisun HS400
So I got it running by changing plugs. Ran it a hour or so now won’t start. It stalled on me once but got it started and drove home. Now won’t start at all. I’ve pulled the air filter tried starting. No luck. Changed plugs again, no luck. The injector does pulse fuel out and it does spark at the plug. Not sure what else to check. Where is the timing chain, how do I check it?
Was out hunting in Montana for a week. Seems like it’s flooding. I originally got it running by changing to a iridium plug.   Then next day wouldn’t start. Spark is there fueling is there. So I Bought a new air cleaner gunna add that and start diagnostics again.
This is an EFI engine. DO NOT PRESS DOWN ON THE GAS PEDAL TO START. Turn key and listen for the gas pump to stop, approx. 5 seconds then turn key all the way to start, keep foot of the gas pedal until it's running.  I also had starting and plug problems at first.
  • 4 weeks later...
I'm having a similar issue with my Coleman UT400, but it started after we left it out in the rain over night (we usually keep it in the garage). We were expecting a large delivery, so needed the garage space for a couple days, and got an unexpected rain shower.  When I went to bring it back inside, it turned over fine, but would not fire. I ordered/replaced the CDI, voltage regulator, and coil and still would not start.  Cleaned the plug, and it fired right up ... this time. After a few short runs, it quit starting again. The plug was wet fouled with fuel. The same NGK DR8EA as mentioned above. I picked up a couple new ones, but now I have to rotate those in about every 3 starts ... either it won't start, or shortly after starting, it will stall and not refire. Also, when a new/clean plug (I clean them with alcohol and then sandblast them real quick) is put in, it will crank in a couple of seconds, but subsequent attempts will take running the starter motor for 10-15 seconds before it fires. Googling brought me to a page that said Hisuns were bad about bad/dirty injectors causing fouling (I have always run premium with stabilizer in it), so I ordered and replaced the injector too but experienced the exact same issue. Seems like the next thing to try would be the ECU, but that's a little pricey, so I'm hoping for other suggestions before I go there. Now, I did try a hotter plug (DR7EA) and it seems to not foul as quickly, but from the get-go it has taken a lot of cranking on the starter to get it to start up, but seems to run better once started.
  • Thanks 1
Update for anyone following.  Took it to the local mechanic he sells and repairs chines bikes. He stated the valves were super tight and that he would recommend checking them every 40-50 hours.  Starts right up bows and purrs like a kitten.
My Coleman 400 UTV has 25 hrs on it, same starting problems, took it to authorized repair center, they found broken piston rings that were causing fouling of plugs,  Broken rings cause engine failure, now waiting for engine replacement.  Still under warranty, had it for three months.
  • 2 months later...
My Coleman is still in the repair shop waiting for Coleman to pay for replacing the engine.  It's now May 12, 2022.  It seems they are slow in paying for dealer repairs under warranty.
  • 4 weeks later...
Was having the same hard start/no start issues as discussed like others. Had been changing plugs trying to convince myself that was the problem. Saw the post about adjusting the valves. The intake had no clearance, appeared to have considerable tension on it. Adjusted it to .005, exhaust was at .005. Started right up, have had no problems since. Thanks to everyone for posting.
    • By Rainman
      I want to put a charger/maintainer for my Coleman UT400 for the winter and need to know if it uses a 6v or 12v battery.
      One search online showed a 6v, but another stated 12v..
      I can look at the battery, but after taking the seat out you cannot see the top of the battery without also removing the top plate under the seat and at 8 degrees outside, I'd rather not be out there too long.
      Can anyone verify what volt (6 or 12) the batter is?
      Thanks in advance ...
    • By johnney
      i have a 2011 hisun ys 400  idles high,once in awhile, runs horrible under load. iv'e put several differant carbs on it , cleaned the gas tank , took off the vaccum fuel pump and put  an
      electric fuel pump.  no change HELP
      this is a carburated engine, but was wondering is there any electrical components that meter the fuel flow,  like  mass air flow senser or something like that could be causing the fuel delivery
      problem.
      ps i have owned this rig since it was new , and haven't had a full  year of flawless riding.
      oh and bought it from menards and told me i was stuck with it.
    • By JDawg
      Help...
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
    • By Gorj
      I have had my E1 since late last summer and I have always noticed that the parking brake was weak or non existent. About a month or so after I purchased it I mentioned to the dealer that the parking brake did not function well. What I was expecting from the dealer, ' well bring it in and we will correct the issue.' What I got was the typical dealer response, "it may just need to be adjusted." No shit!  Well I finally decided to adjust it. A very simple process need only two 10mm wrenches.  Open the bed, remove the pin holding the bed  to the strut and move the bad out of the way. Right in front of the electric motor is a brake disk.  That is the parking brake. It has a small set of brake pads that are actuated by a lever attached to parking brake cable.  There are two 10 mm nuts on the shaft to moves the pads. Release the inner nut and hold it in place while screwing in the outer nut - that is really a bolt. After screwing it in about one turn, tighten the other nut.  Check the parking brake. If it is holding when activated, then you are good, but if not, then you may have to turn the bolt another turn. Do not turn to far or you will lock it up.
