I have a 2008 Joyner Trooper 1100 T2. The Initial 3 second start up sequence will not go, but motor will turn over.
Go to solution
Solved by mixfixdave,
By The Road Hound
Hi,
New to the forum.
Came here looking for some experienced UTV users who can enlighten me about which brand should I pick for my very first UTV or SXS.
I'm between 3 brands and 3 models:
*Kawasaki MULE PRO-FXR 1000.
*Yamaha wolverine rmax2.
*Can am Commander XTP.
The use I'm willing to give it is mostly to go to the range with my wife, load steel targets and all our shooting gear, we shoot a lot, rifles, Shotguns and Handguns for practice, training and competition. (Range is about 10 miles from home)
By Rick A
By mhill
Any thoughts? Suggestions?
Thanks so much
