  • Alex changed the title to Joyner Renegade R4 Transmission Adjustment Access
If the shifter is in the vertical position, no adjustment is necessary.   I hope I never have to adjust the cables.  The adjustments are just to the rear of the shift lever under the center console.  There's no access to the adjustments on my ride.  I'd probably have to cut the plastic console to create an access opening.  The other option is to remove the center console - a job in itself.   The person who wrote the adjustment procedure never addressed how to access the adjustments.
       up.
    • By kadams428
      Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
      Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
    • By SIO
      Does anyone no how to to adjust these shocks. never had shocks with the fast and slow adjustments. But the main problem is it rides ruff. My bike came with the shocks set at 7 1/2" from center of nut to top of spring. The book calls for 5.5" front and 4.7" rear and they say max. Just want to make sure before moving them that far.
    • By Randyh79
      Is there a way to adjust the brightness of the dash light on aHisun 750 sector?
    • By Randyh79
      Does anyone know how to adjust the headlights on a 2024 Hisun sector /Bad Boy Bandit 750? The high beams are where the low beams ought to be.
      Thanks Randy
