elocker 2-4wd for Commando 2x4 2006 650cc
By Matthew Smith
2013 Bennche Bighorn 700 EFI
Figured I’d check for spark and compression while I was dorking around. Compression is 110 psi, but there is no spark. Replaced the spark plug… no change.
By dman66
By SpaceGhost
