    • By Troy C
    • By Brett
    • By JDawg
      Help...
    • By amiracle40995
    • By Ridge Runner
      i have a 2019 Coleman 550 Outfitter.  The tail gate has a pin on each side, that snaps into latch blocks that are mounted on the inside of the tail gate opening.  There are two M6x16 pan head screws(bolts?) that hold the latch blocks in place.  The screws enter from inside the bed body, and I can’t figure out how to access them.  This is right by the tail light assemblies.  I tried taking a pan head screw out of the fender lip, but found out there is not a nut firmly inplace, to hold the pan head screw in.  Bottom line I’m making it worse.
      coleman was no help.  If I could figure out how they attached the tail light, then maybe I could put the latch screws in through the tail light hole.  Any ideas?
      thanks
      Ridgerunner
