I don't of any videos, but to change the transaxle fluid you will need to make a long funnel out of 3 or 4 feet of 1/4" ID  plastic tubing taped to an empty bottle with a pointed top, after cutting the bottom off the bottle, to make a homemade funnel top.
myfirsttracker800sx
  • 2 months later...
I changed my fluids with the Tracker 800 on the ground-no problem. The online Service Manual shows which drain/fill plugs are which and where they are located. You will have to make a fill hose that attaches to a funnel to fill the rear diff.
    • By strike250
      Matt
    • By Tejun
    • By Graffy
    • By lowgear52
