2021 coleman outfitter 400 31 hours on it and my directional lights don't flash, they come on any you can see barely flashing.
All bulbs are working.
Is there a flasher somewhere? Help like them to work same happens when I put on 4 ways barely see it flashing
Thanks all happy holidays
    • By ToughLuck
    • By Marie
