  • Alex changed the title to Can Coleman UT400 be governed to 10mph?
Make sure the seat belts are connected.  This is a built in safety feature on both Coleman and Hisuns  that it won’t go over 10mph unless the seat belts are snapped.
I read the question differently; in that the original poster was asking if a 10 mpg limit could be set, even if the belts are being worn - like if children are using the UTV. If this is the question, then look here:
https://utvspeedsafe.com/
The default setting is 15 mph, but it can be adjusted.
    • By Will Sutton
    • By dman66
    • By John Gubancsik
      I started my UT400 but forgot to buckel my seat belt.  It bogged down and then died.  Only way I could restart it was to press the gas pedal and if I let up on it, it stalls.  Any suggestions?  Thanks.
    • By hetovi
      Hello everyone.
    • By Rainman
      I just picked up a 2021 Coleman UT400 and one of the things it needs is a gas cap. I believe it needs the 2021+ version with mail threads. Anybody know where I can get one? Coleman isn't shipping anything out right now. I believe the part number is P315001811400000. The only after market gas caps I see available are before 2021.
