2001 3010 Mule. Had trouble forever with starting, idling ànd just generally running good. Replaced rusted tank,filter and carburetor kit. Ran like a top for about 6 weeks. Died on me one day and now it will turn over fine but won't start. Valve adjustment is good. Help is appreciated in advance.
remove the air filter and air duct work, down to the carb, give it a few shots of starting fluid strait into the carburetor.(gasoline, or flammable brake parts cleaner will work) If it runs then dies, you have a fuel delivery issue. If it does not fire at all, you most likely have a spark or ignition timing issue.
    • By GunnersTacklebox
    • By Mike Jenkins
    • By Some random dude
      2015 Hisun 700 Utv
    • By Sando
