  • Alex changed the title to 2007 XP700 Polaris Ranger No Start
Engine's need Spark (at the right time),Fuel and compression to start.....
so i'd start by spraying starting fluid or flammable brake parts cleaner straight into the carburetor (or remove the spark plug and give it a burst or two in the plug hole) and try to start it. if it runs and dies, you have a fuel delivery issue. if it doesn't fire on starting fluid, i'd suspect no spark, and then check for spark, first at the end of the end of the spark plug by grounding the electrode to the engine block/metal. if no spark that way, get a screwdriver and stick into the plug wire  and touch the screwdriver to metal on the engine, and see if you get a spark jumping around,
Ok, sprayed starting fluid in the throttle body, engine started but only ran on that.  If it's the fuel pump how do you  check pressure on it without being able to start it, or do you think it is something else. Pulled a 41 on the engine code also.
Thanks for the help.
    • By Mike Jenkins
    • By Some random dude
      2015 Hisun 700 Utv
    • By Sando
