hello
By JimG
By Poppateets
I just purchased a used 2023 Massimo warrior UTV SxS 1000mx with 600 miles on it. I didn't even get a full day of riding and the driver's side rear axle broke. I'm pretty sure it was already going bad because we would hear a noise once in a while. I'm wondering if anyone else has had problems with theirs. Also looking for places to buy accessories.
By Xov
By Kingfish
