Radiator flush
By SouthernGypsy
By JOSEPH LAMAR
By rev6engines
Call or Text:
801) 489-8697
Email at:
[email protected]
Happy riding!!! 🤘
By Greg Kilgore
Plumbing parts list.
2 1" x 3/4" x 1" PEX Tee
1 3/4" PEX ball valve
1 1" PEX ball valve
Wide view of the plumbing.
Kilgore.
