wet clutch
By Dennis
By Josh5696
So I've got a 2022 Axis 500 UTV with only 50 miles on the odometer. It seems to have a strange grinding/squeeling noise coming from the clutch when decelerating or going down hill at lower speeds. Did some research, and found out this is apparently a fairly common thing. Alot of sources suggest the one way bearing is responsible. I'm hearing about quite a few horror stories about these bearings going bad on practically new machines, and when they replace the bearing it goes bad again shortly after.
Has anyone come up with a solid fix for this? I've read it may be possible to run the UTV without the bearing at all, is that true? Are the $20 replacement bearings from eBay and Amazon complete garbage, and is there a better one way bearing out there that's built stronger? Is there something else causing this bearing to wear out faster, or is the stock bearing complete junk?
Any input is appreciated, thanks in advance!
By redneckred
I have a 2012 Bennche Bighorn 700X. I bought it used. It had been sitting in a field for several years untouched. I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel). The machine cranked and ran beautifully. I had it over a year and then the machine quit running. As it would not stay cranked, I narrowed the problem down to a bad IAC valve. I replaced it and it ran as good as new/old. Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear. Then forward quit. I assumed a bad CVT belt and got one. Started removing the bolts from the cover and (3) just turn in the housing without coming loose. (2) are on the bottom, so very little room to do anything with them. I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank. It turns over fine. It gets gas to the injector and has spark. I can spray cleaner down her throat and she would run until it ran out. I have replaced the IAC twice and put a new injector with no change. I went out and put the old injector back in to see if that made any difference and, well, it did. I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off. I have to disconnect the battery to stop it. Before I shoot this thing, what am I missing? Is this an ECM problem or something else I am not seeing? Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving. I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful. Thanks in advance.
By John M in Louisiana
Quick question about replacing the plug. One of the prongs pulled out, so I'm thinking it will be an easy fix to connect the old cord with a new plug but I'm unsure about the specs. 15amp 125v? Is it more complicated than that? I do plan to buy a plug that's water tight.
Thanks in advance!
