The pics don't do justice to the size of the boulders and hills. Plenty of dings under the Trooper after yesterday. There was a Rhino with us and I do have to say it did a great job.
rocmoc n AZ/Mexico
Hi rocmoc,
Great pictures taken by your friends. Living near Chiva Falls I must say the pictures really don't tell how knarly the area is. For those interested in riding the area you have to LOVE ROCKS. The scenery makes it worth while.
Thanks for the pictures.
Gumball
    • By Xov
    • By Browner010
    • By Greg Kilgore
    • By BernieG
