Trooper riding in Tucson
rocmoc
Hi rocmoc,
Great pictures taken by your friends. Living near Chiva Falls I must say the pictures really don't tell how knarly the area is. For those interested in riding the area you have to LOVE ROCKS. The scenery makes it worth while.
Thanks for the pictures.
Gumball
    • By Browner010
    • By Greg Kilgore
    • By BernieG
    • By Xov
