Skid plate debate
By KimAC
I need a pair of front shocks for a Landpride Treker 4200NT, from 2005? Does anyone know of a good salvage yard - or another source?
-Kim
By Jacob E freeman
By Kingfish
By REDfletching
Spent today at a Honda dealership looking at their 520 side by side, then on the way home past our Lowes noticed they had several new UTVs on site, so we U-turned and ducked in there. We were impressed that all that came for $9,999 metal whole length skid plate, nice sized bed, roof, windshield, side mirrors, winch, upgrade looking tires… all of which would have added thousands of dollars to an already expensive Honda 520. Now Honda does have a great reputation from my trusted UTV experienced buddy, so it has that going for it.
By Alien10
I added lights to the Coleman Outfitter 550 last fall. I bought lights on line from Nilight, a 300 W 12" light bar mounted forward and 2 square 4" floods for the rear. Those are mounted on the roof corners facing rear and downward just beyond the tailgate. Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights. Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch. Rear work lamps were wired in using a rocker switch installed in the dash. Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
What have you used if anything for auxiliary lighting on your UTV?
