Tboss 410 putting a fan under seat to blow heat up during cold
Greetings All,
By rdborra
By rsar
By downseast
Hi everyone
By downseast
Hi everyone
When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
I haven’t changed the Lambda
sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
I believe the T Boss was worked on by the previous owner
