Thank you, sir! So, the upgrade is switching to an iridium plug? Is it a different heat range? I know mine was running rough and difficult to start, so I pulled the spark plug. It was fouled, so rather than clean and replace it, I changed it out for a new plug. I gapped it according to the manual, and it runs much better, and starts quicker. It's the same plug, just a new one.
I thought that iridium and platinum plugs were for extended use? Personally, I don't like them. I use NGK V-groove plugs in my vehicles. The UTV gets a standard copper core plug. My reasoning for that choice is a combination of price and performance. Have you ever tried to remove a spark plug that's been in a head for 100,000 miles? It's lots of fun, let me tell ya. I have also seen the platinum tips disappear, causing a poor performance issue.  True, I may spend more on plugs over the life of the vehicle, but I don't get plugs that are nearly impossible to remove, either. Platinum isn't as good a conductor as copper, either. I would think that would be harder on the coil, since the resistance is greater. I don't know about the conductivity of iridium, but I do know it costs considerably more than the copper plugs do.
they use less voltage compared to platinum and copper, so if your coil is not sparking as hot as when it was new, it won't be as heavy of an electrical load, is what it sounds like, it also creates a more concentrated flame and combustion area.
I've thought about trying one in mine, some people note a better throttle response.
Wasn't the idea behind the platinum tips, as well as the iridium tips, for longevity? I have never been a believer in the factory claims that those plugs don't need replacing for 100,000 miles. Guess I'm old school.
Yeah, I would have to try that myself. I've always been a sceptic of noticable performance from a switch in spark plugs, unless it's a faulty plug(s). I have a real issue with the E3 spark plugs. The spark is going to take the path of least resistance, so there will only be one spark. Now maybe where different types of metals are used in the electrodes that can conduct electricity better, but can that actually be felt in the performance? Now a good coil or a system that enhances the spark, maybe.
    • By John M in Louisiana
      Thanks in advance!
    • By Robby
    • By Bobby Courtney
      I have a 2021 Coleman 400utv with 60 miles on it. I bought as project. It’s idled ruff and fouled plugs since it was new. I have removed and cleaned throttle body new injector new idle air valve new oxygen sensor. Installed ngk iridium plug. Starts and run good for about 5 or 6 miles and fouls plug. It runs rich all the time. I’ve done reset on ecu. I’m about to think it’s time to try a new ecu. Anyone please help.
    • By Travis
      Many people have issues with the kawasaki FJ400 engine  fouling out spark plugs, after  working on a  few FJ engines and 600 series Mule's with this issue,  i can say the fix for this issue is using a slightly hotter spark plug... the factory recommends a BPR6ES NGK plug.... the Number in NGK plugs represents its heat range and somewhat odd, the lower the number the hotter the plug, at least as far as NGK is concerned. If you have  a Mule fouling spark plugs try installing a NGK BPR4ES spark plug.
      FROM NGK
      A hotter heat range spark plug has an insulator design with a longer heat flow path to the metal shell of the plug. As a result, more heat stays in the ceramic firing end and less is dissipated to the engine. A colder heat range spark plug has an insulator design with a shorter heat flow path to the metal shell of the plug. As a result, less heat stays in the ceramic firing end and more is dissipated to the engine. For a spark plug to function properly, it must have a tip temperature high enough to burn off carbon deposits (self-cleaning) and avoid fouling, while remaining low enough to avoid overheating the ceramic firing end and pre-ignition.
