Hi, just got this 2008 motobishi 700 which is technically yamaha rhino. Going trough replacing fluids and can't find info on how to change oil/fluid for the chain drive or gearcase, whichever its being called. There is a fill screw on top of shifter gear - however i can't locate a dipstick or drain plug for that fluid - please point me in the right direction here.
  • Alex changed the title to 2008 Motobishi 700 transmission fluid
hi, this is the fill bolt I am referring to, marked on the image
once the shifter cover is removed you can see that there is some kind of lubrication present, my guess its a gear lube, however i wanted to drain or extract it and put in new one to the correct level.
\\e3L-QzkcNGE7iX4u7haqDer9xd3P3gYfoEMGb8tjqVWvM8gmStVY7IF00vXuLlvCBC1fNxjq9jUTjDJ5M9cwiAWeVLqys2D4pRjxnDGnxAoD4SUnzvYJhitqu1K0lgEk1Hny5BJpn1xZD4bXAvAxthhk2YF1Tf1kc2ePzUMBklhzy-N1YQJfVYzPC9MhXSgDfsTEqv2Tna2A93tUG2b_HHOI6FzF1m-HIZbAlmPUukKR4YJ5WLz2SaoPrpyRkZk-7vDC1e1QE3T8jWTTpUhU-mF7vu6jDqXbTmdbjSxgCZ93Mf-ayxNl57ePzyqL9FTeyDelloD_JEtuWIDlNYh2hZQyiLT1EDtKy1wTag2kBZA4ssnlbaVIPZYQd18IbGBurnb76A8UJwmRMvGIKjnFPkYGgxvdagARR_FPEHa534STqZvoRy8CdXZPKNFQtp9hKSR191qx-TvpytvoIlhPpQHNFEvzApnqIL8sZgdMrunGb44D41Xl75SvSO4qXsnviqYylyB3VGTVRI0qUU19T1VQKj7hgr-qJm239ddw66NWkJ-oJlqLNy5dgUw0NNKPMs-j_XK05oPkYYdnc0QvI7fC-_-GYszSDd97QD89Dpm2ApD9rE17oFPzsSCGlIg8GD9x7vl_hgVWYdzPFQeEgWzVv0A-viRGMUZkmOmh5Y1pZCXYECVWj3D0b2iARqEU_4oxTooWiPHArCMInk6ym6_iXg=w3133-h1763-no?authuser=04K5oJdRubBeT-Wa3Vm_3EvnfkKZuVksdegdnmqyuHjqktdJAvWZMYunsvhjkq6oPbaXZbKOycvmiMcpE9UbQcUy4FIipxxE6Fmi78n0Gi8xWO3l6EknH8iKqnfIrAD8x_CBypED0oPpincer-e4GiIEH8DMBACSn8LWPurISZuZR9Y4yFqbLbSvg-nkUsCyqv6qTo5Z0pRplTh88naQRTGbUr9_yaFXuAUym5wAyK7AAkUSVganIgluGmmCbqri2l57JxnKZ10gSJdHM1hWr8RYEIPInZ8JSOpfH8U8_whICN3ZZhB5OlYddesNW9bYsDSMhYj8nOhMe-CNAf17dc_SkBTqjaJdeb2Hy1CuqZWvHlDOHOpOfRoRbjY5wbsakyywRa6IHUAAJ_cNzlcjiIHv-V3a-avpt2lAj0b7g57U3g02Y_teCbYEBcG-HkOLjDHBHIdTWBgEvatiNikzanjt-s9S4HRVfnDid14HU_TRsssPZxRLYWUvtppcVAE5tjko0tqyek-bz2yMj8sRBf7yYfxCaFAmIyeXzAILBvjYNubao-pXExaGlinWBFkx0aFiASQpcjcmyODy_hTQaPjZXzPZg-ZKd5nKCVoZl3nsLVMu1O0TaJHhy17Q-eYat2yKcjaaktYVCIkUcxlpiOkgQnWgEYgCs414HVwApa2gqRl2UcesqI02gpoo0kghCe4aeo-35BytUTHlhU0zo4YO4cg=w359-h202-no?authuser=0
    • By The Road Hound
      Hi,
      New to the forum.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
    • By mhill
      Any thoughts? Suggestions?
      Thanks so much
    • By staind
      thanks Dan D. aka staind
    • By allinone
