driveshaft carrier bearing greesing
Guest Lenny
I just lubed my drive shaft carrier bearing. It was nearly all but impossible to get at. Finally after unbolting the bearing so I could slide it from side to side, I took out the stock greese fitting, which is on the top side torwards the front, and replaced it with a 1/4" tube fiting which uses a 1/8" pipe thread. This pipe thread is close enough to the stock fitting so the start of it threads can be ground down to form a taper so the threaded hole can be found when trying to screw it in. The rest of the threads were ground down about 1/3 the depth of the threads. Getting to the fitting placement is tough but doable. When finally started an open end wrench can bearly be manulipulated to get it tight. I then pushed on a peice of the 1/4" tubing and secured it with a ferrel and ferrel nut. The tube was about 8" long. At the other end I screwed in a greese fitting that had a 1/4 - 28 thread. If the tubing is lightly heated and a tapered object is used to lightly flair the end, you can get the greese fitting to tightly thread into it. Now the fittiong hangs down where I can easily get at it. Greesing from now on will be much easier.
Guest Lenny
Lenny, are you talking about the grease fitting on the carrier bearing located roughly between the seats?
rocmoc n AZ/Mexico
Yes
    • By rdborra
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By The Road Hound
      Hi,
      New to the forum.
      *Yamaha wolverine rmax2.
      *Can am Commander XTP.
    • By Robbie Wyre
    • By allinone
