Hoping someone can help me with a question I am looking at a HUV 4414GX it says its 4 wheel drive but doesn't have a 2wd or 4wd lever, did they make a 4414 with fulltime 4wheel drive.  I cannot find any info on the different models and what they offered, any info would be appreciated.  Seems like a nice UTV just want to verify before I purchase.
    • By SouthernGypsy
    • By JOSEPH LAMAR
    • By Texjpr
    • By Gary Gallo
